Epic old school size trees
 Post subject: Epic old school size trees
PostPosted: Sun Mar 29, 2020 6:19 pm
The Wargaming company (thewargamingcompany.com) sells the old school epic sized trees. You get a pack for 15 bucks. The larger pine trees are too tall. They come with MDF bases. You will need to seal them as they shed flock easily. Image
mattie
http://maashes.blogspot.com/
 Post subject: Re: Epic old school size trees
PostPosted: Mon Mar 30, 2020 4:10 am
Do you have a link to the trees you bought that you think fit best?
I'm not seeing any packs for $15 - but I'm seeing a bunch of trees that might work well?
Thanks!
PostPosted: Mon Mar 30, 2020 12:14 pm
Compared to old GW batreps etc, sure. :)
They're actually still on the small side for actual trees, though. What we think of as correctly sized for Epic is more like a large bush than an actual tree. :(
The Wargaming Trader
PostPosted: Mon Mar 30, 2020 5:38 pm
This is a problem I’ve always had with trees at all scales of wargaming. Everyone makes trees so freaking small.
Thanks,
Troy
PostPosted: Mon Mar 30, 2020 5:54 pm
Thanks!
I got mine at a Con. They are 25 on the site. 25% off until 6APR.
mattie
PostPosted: Mon Mar 30, 2020 5:57 pm
It is true the trees are small. If they were the correct size, they would be unplayable. In Epic they are more tokens representing a design concept. Area terrain. As long as you can recognize what the object represents and the limitation of the object then it doesn't matter.
mattie
PostPosted: Tue Mar 31, 2020 1:56 am
Im not so much bothered by them being too small as not being varied enough. The thing about trees is they they start off small and get bigger... so can be in a wide range of sizes even for the same species.
Also I’m not so sure trees are incorrectly scaled. I mean compared to the varying sizes of models. They do look wrong in today’s world of “true scale” (as if there was ever a reference for what is true) titans. But the trees did come first after all.
PostPosted: Tue Mar 31, 2020 11:32 am
I agree that we're just using them as tokens, so the size isn't that critical, but larger trees definitely aren't unplayable, for exactly the same reason!
For example:
Although this is partly because we play area terrain as being as high as the highest element within it, so tall woodlands are needed to block LoS to/from Titans.
P.S. Apologies if my earlier post came across as aggressive. :-(
I generally work from the GW infantry (and the slightly smaller pre-3rd ed stuff, at that. Which puts a mature beech tree (up to 160 feet/40 metres) at 150-160mm high.
PostPosted: Wed Apr 01, 2020 5:04 am
Thanks!
Which type/size did you end up getting?
PostPosted: Fri Apr 03, 2020 5:49 pm
[/quote] I got mine at a Con. They are 25 on the site. 25% off until 6APR.[/quote]
Which type/size did you end up getting?[/quote]
I got these two
https://thewargamingcompany.com/product ... ees-short/
mattie
