TW: Warriors, how many activations?
 Post subject: TW: Warriors, how many activations?
PostPosted: Sun Jul 17, 2005 7:34 pm
Since warriors are bought as a brood do they activate as one or as individuals ?
PostPosted: Sun Jul 17, 2005 8:37 pm
Activate as one.
PostPosted: Mon Jul 18, 2005 2:10 am
So If you add extra warriors you just get a larger foot print.
That makes things very interesting.
PostPosted: Wed Jul 20, 2005 9:03 am
Quote (xen3 @ 17 2005 July,21:10)
Hmmm...unsure how you'd add extra warriors. Each Brood of TW will act on its own and
there's no way (in the current version of the NidList, IIRC) to combine Synapse broods. :(
...or am I missing something? ?:D
Larry
"Going into hyperdrive ...is unpleasantly like being drunk"
"Well, what's so unpleasant about being drunk?"
"Ask a glass of water"   - HHGG
PostPosted: Wed Jul 20, 2005 2:25 pm
Synapse creatures can combine to form a single swarm in the most recent list.
PostPosted: Thu Jul 21, 2005 2:45 am
Quote (nealhunt @ 20 2005 July,09:25)
Ah, cool!! Hmmm... could you tell me where it's been posted? I've been following these
discussion lists pretty closely but must have missed it. :( :(
TIA!
Larry
PostPosted: Thu Jul 21, 2005 1:24 pm
I don't know if it was posted.  Maksim had been posting the revisions in locked/pinned threads but the latest came out not too long before the forum change and I'm not sure it made it to the boards.  He hasn't posted it here as far as I know.
Latest versions is 5.40B and it definitely had combined SCs.  It might have also been included in 5.35.
If you email Maksim, he will put you on the distribution list to receive the .doc file as he updates new versions.  I believe the next update is due out soon.
PostPosted: Fri Jul 29, 2005 6:41 pm
Quote (nealhunt @ 21 2005 July,08:24)
Hey all -
Sorry for the slow reply... :(
Neal, I have to admit, I doubted you... :) ?But then I went back and re-read the
Nid armylist (v5.40B) and found this text in T1.30 Design Concept: Tyranid Swarms...
Synapse creatures can work together and share broods as two ?formations
effectively combining into one new formation. In this fashion, Tyranid formations
can provide protection against losing a Synapse unit and having an entire brood
go to ground.
Hmmm... I've read and re-read that text many, many times... and I'm still not clear
on what it's saying. Maksim, could you help me out by telling me what the *intent* of
the rule is? Is it supposed to allow two (or more?) Synapse Formations to combine into
one BIG formation (ie, all the Synapse creatures and all the Brood critters under their
sway acting on ONE activation?
...or is intended to simply clarify that if all the Synapse critters in a given Swarm are
killed, their now-Synapse-less brood critters can count as being under the control of any
nearby Synapse critters (provided they're within Synapse range?)...??
...or is it something else? :oo
I don't like to sit back and sound like a nay-sayer... but when I read that rule as written,
it doesn't "define" anything for me... it just leaves my confused.
Another thing confusing the issue for me is this text in the previous paragraph...
Starting with the second turn a swarm consists of one synapse creature
formation and all the brood units within 15cms of a unit from that synapse
creature formation.
This seems to directly contradict the 'combining' rule in the next paragraph.
Maksim, if you could share what the intent of the rule is, I'd be happy to help
rewrite/clarify them so that others can pick *me* apart... :)
One last (unrelated) question, Maksim - did you ever get the Nid Ref-Sheets
that I emailed to you? I can resend them if not.
As always, thanks for all your work...
Larry
PostPosted: Fri Jul 29, 2005 8:20 pm
Carp.  I am apparently developing a habit of closing the window instead of hitting the post button...
It is confusing and I have also asked Maksim for clarification.  The potential rules interactions for combining synapse nodes are extensive and will require a detailed explanation when it gets to that point.
The latter text you quoted has been there since v1.0, with a minor mod to refer to SC formations rather than SCs.  It was not changed to reflect later mods which contradict it.
The former text was a later addition (somewhere in the 5,x series, iirc) and showed up after discussion of combining SCs into a single swarm.  Maksim has also explicitly stated on here and the SG forums that you can combine SCs into a single swarm.
I don't think there is any question as to intent from all that, but none of that is apparent from just looking at the actual text.
