AMTL Reaver Setups
 Post subject: AMTL Reaver Setups
PostPosted: Fri Mar 25, 2011 9:57 pm
after failing at mainstaying a warlord in 3000 points ive opted for double reavers. right now I am running:
(just the weapons)
Reaver
quake
quake
landing pad
Reaver
lasblast
lasblast
lasblast
+25
i have found both of these titans to perform admirally on the tabletop, but I am curious to see other builds that people like to use.
 Post subject: Re: AMTL Reaver Setups
PostPosted: Fri Mar 25, 2011 10:34 pm
the 2x quake +CLP reaver is rough, but I've found it becomes an early target. Against IG and Marines you may find it's for BTS target and that it goes down before doing much of anything.
Another build that's a little less scary is 2x inferno cannons +CLP. gets some decent range and ignores cover but doesn't quite have the same fear inducing capabilities that the 160ish cm MW barrage has.
I've messed with a similar build as your second one, but I drop one lasblaster for a TLD, minus one shot and -50 points since you don't have to worry about the surcharge which gives you enough for CML.
Another one that's had some luck was 2x VMB + apoc missile for AP stuff and an anti assault version with a lasburner.
-Vaaish
PostPosted: Sat Oct 27, 2012 11:40 pm
To reinforce this topic:
Reaver
Turbolaser
Volcano Cannon
Laser Blaster
CML
Nice tank/WE hunter IMO. What do you guys mean?
PostPosted: Sun Oct 28, 2012 8:47 am
I quite like:
Laser Blaster x 2
Volcano Cannon
Use the LB to strip shields, then Volcano cannon with the TKD3
Also for a more aggressive theme:
Melta Cannon
Laser Burner
TCCW
PostPosted: Sun Oct 28, 2012 12:38 pm
novemberrain wrote:
I quite like:
Laser Blaster x 2
Volcano Cannon
I like this configuration also.
PostPosted: Sun Oct 28, 2012 5:01 pm
Yes, sounds well. But there is no carapace Laser Blaster for the medium robot. But Turbolaser is not so bad and 25 points cheaper.
PostPosted: Sun Oct 28, 2012 7:55 pm
thunderbolts work well for AA and get you an extra activation.
-Vaaish
PostPosted: Mon Oct 29, 2012 9:06 am
Another one I am thinking of is:
Plasma Cannon x 2
Support Missile of some kind
Because the Plasma Cannons are slow firing they sync better with the support missile than most other weapons allowing you to target the most efficient formations without "wasting" the other weapons.
