Post new topic Reply to topic  [ 441 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 30  Next
Ghost's Paint Blog
 Post subject: Re: Ghost's Paint Blog
PostPosted: Sat Nov 06, 2010 11:44 pm
I think I can call this Minervan venture a qualified success. The magnetization is super easy, and works amazingly well. The qualifications are that the replacement barrels I'd thought to use are too chubby, and the angled mantlet means drilling it level is a pain. Both relatively minor.
The tools and process. Put a magnet into the post hole on the chassis. I used clippers to remove the peg, and filed it flat. I used my scribing tool (top) to mark the center of the hole for the magnet. I then used a 1/16" bit as a guide, and then used the 5/32" bit to flesh it out. The vertical sides of the hole should only be <1mm deep, though of course the tip of the bit will be deeper. Then glue in the magnet. For the small UPV turrets, I just cut off the post and glued on the magnet, since drilling the turret would have destroyed it.
Here is the warning I am required by law to add: MAKE SURE YOUR POLARITIES MATCH! If you want things interchangeable, all your chassis and all your turret magnets need to be properly oriented. No one likes turrets that blow off as soon as you remove your hand.
You end up with this:
And this:
Two of the Magnets on the UPV Chassis weren't dry, so I left those turrets off. Which reminds me. Make sure things are dry before you start putting turrets on and making pew pew noises. The attraction between these mags will break unset superglue.
PostPosted: Sun Nov 07, 2010 2:26 pm
Turret WIPs.
Front to back: Leman Russ, Leman Russ Vanquisher, unmodified Achilles MBT.
Thoughts?
PostPosted: Sun Nov 07, 2010 2:53 pm
1/16" brass rod and 3/32" tubing from k&s engineering.
PostPosted: Sun Nov 07, 2010 3:03 pm
looks really nice and clean :)
PostPosted: Sun Nov 07, 2010 10:12 pm
nicely done Ghost
PostPosted: Mon Nov 08, 2010 1:54 pm
These things are a breeze to paint.
First Salamander scout squadron done, second just needs detail work.
Look! I'm WMN, but without the talent!
Pic with turret removed.
PostPosted: Mon Nov 08, 2010 1:55 pm
Awesome :)
PostPosted: Mon Nov 08, 2010 3:26 pm
looking good :D
Tim NZ
PostPosted: Mon Nov 08, 2010 4:17 pm
Aww. Give yourself some credit. These look ace :D Some kind of unit designations (you could use decals) would make a nice finishing touch I think.
PostPosted: Mon Nov 08, 2010 6:17 pm
very nice colorsheme
PostPosted: Tue Nov 09, 2010 12:16 am
I'm not sure how to do this in a fashion that allows the modularity I want. I will continue to consider the problem.
PostPosted: Sat Nov 13, 2010 4:08 am
I really like you paint scheme. Could you tell us how you wnet about it?
"Don't use finesse, if force will solve the problem."
- Lieutenant General Michael O'Neal
PostPosted: Sat Nov 13, 2010 4:17 am
Black primer. Fenris Grey undercoat followed by a Space Wolves Grey drybrush. Don't be skimpy on the drybrush or the later wash will drown it out. The light grey is Astronomicon Grey with a Skull White fine-edge highlight. Metals are all Chainmail, painted on the vents, overbrushed on the tracks. Give the thing a liberal wash of Badab Black and let it dry. Weather the tracks to taste with a drybrush of Vermin Brown. Headlights are Bad Moon Yellow, and the taillights are red gore.
Users browsing this forum: No registered users and 132 guests
