Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Off-Board Formations - General Rules
 Post subject: Re: Off-Board Formations - General Rules
PostPosted: Sun Apr 25, 2010 1:30 pm
Ok, Please can we sort out how 'Gates work with respect to being blocked, and where formations cannot completely deploy, because these are the main problems that players have encountered over the years.
IIRC, the answeres that have been presented are
  1. If the gate is covered by an enemy ZoC, the off-table formation must 'assault' that enemy out of the gate
  2. If the off-table formation does not have sufficient space to deploy, either
    1. the remainder of the formation is destroyed, applying that number of BMs to the formation
      or
    2. the assault is fought and if successfull the remainder of the formation enters the table otherwise they are automatically destroyed before any hackdowns are applied
  3. If the gate is 'blocked' (however that is defined) then either
    1. The gate cannot be used at all
    2. The number of units that can exit are limited to the number that can move into B-B with the blocker
    3. The gate cannot be 'blocked' (however that is defined)
PostPosted: Sun Apr 25, 2010 1:31 pm
Mephiston wrote:
Your last sentence should include "....activate, or all remaining ground formations are on overwatch and wish to retain that status."
Which interestingly gives us a precident for passing formations activations too.
PostPosted: Sun Apr 25, 2010 1:35 pm
From the FAQ
Q: Can a unit remain on Overwatch
into a following turn?
A: If the Formation hasn't fired by the
end of the turn, then they can remain
on Overwatch into the following turn.
So this effectively allows you to "pass" all formations on OW, but you can't do this until all your none OW formations have taken an activation.
PostPosted: Sun Apr 25, 2010 1:40 pm
Not sure about that Meph. When Neal introduced the idea that OW could be carried over (which I also felt was another breach of the same principles), he said that a player could 'pass' activating the formation rather than being forced to attempt to activate it. So I am sure that the majority of the forum will now say that you are no longer forced to try to activate a formation on OW.
(you beat me to that Meph)
But it's not a "pass", in the Action Phase, it's a "pass" in the End Phase.
You don't point at the formation on overwatch and say, "pass", and force the opponent to go again, the formation on overwatch never has an activation *unless* you're taking it off overwatch to do something else.
I've "stalled" with a formation on overwatch from the previous turn by giving it another overwatch order, but that took the risk of a failed activation.
PostPosted: Sun Apr 25, 2010 1:48 pm
I must say I am not a fan of the eternal overwatch rules change.
PostPosted: Sun Apr 25, 2010 3:45 pm
That's what I mean, passing on your remaining formations who are all on overwatch is essentially the same mechanic as passing on all your remaining offboard formations.
PostPosted: Sun Apr 25, 2010 10:29 pm
OK, so can we now move onto the questions around gates that I summarised here.
PostPosted: Sun Apr 25, 2010 10:42 pm
I think that needs a new thread Ginger.
PostPosted: Mon Apr 26, 2010 12:30 am
Ginger: This is for general off-board formations. Specifics of portal/gate blocking is not a general issue, it's list specific, so should be in a different thread.
PostPosted: Mon Apr 26, 2010 2:09 pm
Yeah, that's how I see it.
It's not really a "pass" in the way I think about it. It's more like a final "activate out" where you declare everything is staying where it is and foregoing a "real" activation.
Edit: And yes, I agree that this would be a change in regards to the prior discussions on webway formations being allowed to Regroup on a Hold action after a failed activation.
Edit-edit: I also agree that this breaks the core idea of 1.6 that everything has to activate. However, either version of OW and any of the off-board rules break that anyway.
PostPosted: Tue Apr 27, 2010 11:10 am
Neal, are you now suggesting that an off-table formation that fails to activate and must 'Hold', is now forced to enter the table with a BM??
Yet again this may be appropriate to Necrons, but I must protest that it is *not* fair to the Eldar. If these mechanics are needed for the Necrons, then they should only be applied to the way that the Necrons work off-table! And, please note that the way I have always played Eldar 'gates (Marshalling off-table) does not break 1.6 so would not cause these problems (nor did the original way that OW worked)!
PostPosted: Tue Apr 27, 2010 11:29 am
Ginger: The OW FAW makes it clear that 1.6 is not holy writ, and can be overridden. This is a case where overriding it makes sense, and seems to be what everyone except you is doing if this thread is any judge.
PostPosted: Tue Apr 27, 2010 11:56 am
Hi Zombo,
While we may be actively posting, there are many who don't. I (and others) disliked the change to the OW rule, not least because it made Ork formations on OW able to act in an 'un-orky' way by staying on OW.
As you know, IMHO this set of 'changes' to the way that off-table formations work is only really needed for Necrons, and is now apparently set to force failed activations on-table with a BM. Both activities are not fair to Eldar, which are hard enough to play well and do not need further 'nerfs', quite apart from not conforming to the concept of a 'cautious dying race'. Indeed, being forced to arrive on-table having failed to Assault is quite the reverse of a 'cautious' attitude - though it may well be considered the mentallity of the 'metal heads'.
PostPosted: Tue Apr 27, 2010 12:06 pm
I believe the intent is that an off-board formation that fails to activate and and must 'Hold', either moves onto the table with a Blast marker or *loses* the rest of its activation, remaining off-board with a Blast marker.
It doesn't get the opportunity to regroup if it's not on the table, but it isn't forced onto the table; it could then attempt to rally in the End Phase though.
