[Epic] Tyranids for Trade
 Post subject: [Epic] Tyranids for Trade
PostPosted: Fri Feb 07, 2014 2:53 am
Hi everyone, I have a bunch of Epic Tyranid stuff that I'm looking to trade (Wants list at the bottom of the post). Selling may be possible, but I'd really rather trade.
Most of my pics have the models labelled- sometimes as a grid. If you want or don't want specific models let me know their grid reference and I'll make sure you get exactly what you want.
Dominatrix (Dominatrices?)
Model A is assembled and painted, gaps have been roughly filled but it's done well enough to pass casual observance. Model D had the tail cut off, but the tail is included and fits back on quite well.
Hive Tyrants (Large version)
All other than E3 have the swords slightly bent, but that can easily be fixed. There's enough of these guys to use as a 40k unit of some sort.
Hive Tyrants (Small version)
Model B has a blob of putty over the top half of his face. I don't know why, and I don't know if the face is still good under there.
Tyranid Warriors (long bases)
A2 has all deathspitters, B2 has two sword wielders. Otherwise these guys are pretty good, with no breaks I've noticed.
Tyranid Warriors (square bases)
No breaks I've noticed.
Termagants
Base A4 has one model with a broken neck, although the head hasn't fallen off yet. Otherwise these guys are good.
Genestealers
B2 has the top of one claw broken off, but otherwise I think these guys are also good.
Gargoyles
Converted to be flying thin metal rods. One or two have also had their wings separated, but it's done fairly well. Obviously these guys are fragile and have not survived well, although the models themselves are fairly well intact. With some TLC these guys can be fixed up. Each of these bases has 5 gargoyle models.
Gargoyles 2
Exactly the same as the other gargoyles, only I don't have the missing parts to make 5 per base. A1, B1, C1 have 3 per base, A2, B2 have 2 per base and C2 has 1 model.
Lictors
The arms of A3 are glued on upside down, but otherwise all are good with no breaks that I've noticed.
Malefactor
Dactylis
Exocrines (Lot 1)
Exocrines (Lot 2)
Note that E1 has had some large horns sculpted on- and not particularly well- but still looks ok.
Trygons
Still on Sprue
Sprue A hold a Warrior and Gargoyle unit, Sprue B only has warriors left. Both sprues have been undercoated black.
Plastic Bits
2 warriors and 3 gargoyles glued to a base, then 'painted'. Warriors have brokn guns and the warrior closest to the camera has broken ankles. These guys may be salvageable.
Metal Bits
6 Dactylis bodies and 6 pairs of Malefactor arms. For making Dactylfactors?
Bases
One base with metal rods (probably intended for the gargoyles)- rods are bent. 7 full square base sprues (one apart from the rest to show completeness). 2 part square-base sprues (one with 2 bases, one with only the base holders left).
Wants List:
Metal Epic IG characters (Latest models)
Epic Leman Russ Vanquisher
Epic Leman Russ x3 (Latest models)
Epic IG Sentinels x4 (Latest models)
Epic IG Bombard x1 (Latest model)
Epic IG Griffons x3 (Latest models)
Epic IG Hellhounds x3 (Latest models)
Epic Tyranid Biovores x12
Epic Eldar Warp Spiders x20 (4 bases)
Epic Eldar Dark Reapers x10 (2 bases)
Models are located in Australia; if buying buyer will pay for postage, if trading it will be assumed postage costs cancel each other.
Any questions feel free to ask!
 Post subject: Re: [Epic] Tyranids for Trade
PostPosted: Fri Feb 07, 2014 3:13 am
Hey
definitely want those genestealers
Would also like Trygons, Small HiveTyrants A and C, Dactylfactor bits, and depending on price, Exocrines
I'll see what I can do with trades, but money is simpler
PostPosted: Wed Feb 12, 2014 9:49 am
G'day Geep, I'm interested in some of this stuff, but I'm not on here too much.
Could you contact me on this email address: ramble_on@optusnet.com.au
PostPosted: Fri Feb 14, 2014 11:41 am
Also intersted in the Trygons, as well as in "Small Hive Tyrant A" and "C" and one big Hive Tyrant. Please tell me your price for everything.
PostPosted: Sat Feb 15, 2014 1:43 am
Hi Largo_W,
I could easily sell you a big Hive Tyrant, but unless you have things to trade I'll be selling things on a 'first come, first served' basis. So I could trade you for the Trygons or maybe the smaller Hive Tyrants (see my wants list at the end of the first post), but you're probably a bit late for me selling them to you.
PostPosted: Mon Feb 17, 2014 2:39 pm
No problem. I sadly cannot deliver anything from your wanted list.
