Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4
Probability distributions etc
 Post subject: Re: Probability distributions etc
PostPosted: Sun Oct 30, 2011 5:30 am
An experiment...
Without using any calculation, post your best guess for the outcome of the following assault (win/lose/draw):
4 Assault Marine Units (3+CC 4+Arm) vs 8 Ork Warbike Units (4+CC 5+Arm)
- All units engaged; no supporting fire; no BMs.
What percentage of the time would you expect the marines to win? What's your guess if you add a BM to the Orks before the assault?
(i wrote a script to calculate the outcome so i'll post actual result up after some guesses)
PostPosted: Sun Oct 30, 2011 6:18 am
adam77 wrote:
An experiment...
Marines: 35/55/10 w/l/d
PostPosted: Sun Oct 30, 2011 9:08 am
My gut instinct is about the same as Hena, marines win 1/3rd, orks 2/3rd. But I've got a feeling that the odds are a bit closer. With BMs on the orks it should be 50/50.
PostPosted: Sun Oct 30, 2011 7:18 pm
Without BMs or any inspiring characters on either side, and assuming all units are in contact, the Orcs should suffer between ~1-2 hits while inflicitng ~2 hits meaning they go into the resolution at +2 or +3. So they should win ~75% of the time, a draw ~15% and the Marines win only ~10% of the time.
With the Orcs on 1BM, the assault resolution slightly favours the Orks, who should win ~46% of the time, a draw ~14% and and Marines win ~40% of the time.
PostPosted: Mon Oct 31, 2011 12:45 am
if you abstract armour out you get 8 marines vs 12 orks - so i'm going to guess orks 66% of the time.
An actual game situation would get a certain degree more calcualtion
PostPosted: Mon Oct 31, 2011 7:50 am
Hmm mostly ~33% and one at ~10%, pretty good. Here's what I calculated...
Without BM
pWinA: 19.1%
pDraw: 10.4%
pLose: 70.6%
A single BM evens things up...
With BM
pWinA: 41.8%
pDraw: 13.0%
pLose: 45.2%
@Ginger: that was a scarily close estimate for the BM case!
I put the script here: http://traitor-legion.appspot.com/assau ... lator.html
Feel free to have a play...
PostPosted: Mon Oct 31, 2011 9:29 am
Cool script! Going to play around some with that.
Now if it only had first strike, given how this debate started :P
PostPosted: Mon Oct 31, 2011 9:31 am
Errrr, yes, i should add that...
PostPosted: Mon Oct 31, 2011 11:19 pm
@Adam - why thank you kind sir, though my maths is a little rusty. It is purely a case of considering the Assault resolution. In this case, the combat will end up on average with 0-1 difference in kills. This actually emphasises the point made by most 'veterans' that it is crucial to prep a target, and also why Inspiring Characters make such a difference.
In the end you can go into the dice off up to +/- 5 and it is a fairly simple thing to work out the probability in each case. Where you are likely to experience some variation, just take the average between the two extremes
