Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
How exactly does this work for Iyanden
 Post subject: How exactly does this work for Iyanden
PostPosted: Tue Apr 06, 2010 9:53 pm
SPECIAL RULE – The Living Few
Iyanden suffers with a depleted population which has driven them, in times of
need, to raising Spirit Warriors to fight in their stead. As a result, Iyanden
Craftworld Eldar Armies may not have more individual Eldar Guardian Warhosts,
Aspect Warrior, Ranger, or Windrider Troupes than they have Spirit Warrior
Warhosts.
Ok, so does that mean that if you have only one guardian warhost and one spirit warrior warhost, you cannot include an aspect warrior troupe?
i may be kinda dense on this one, but i was curious how to handle this rule.
 Post subject: Re: How exactly does this work for Iyanden
PostPosted: Tue Apr 06, 2010 10:04 pm
I don't know if you play WFB, but it works like the old rules for Skaven. You may not have more of any specific formation than you have Spirithosts. You may take 1 Eldar Guardian Warhost, 1 Aspect Warrior Troupe, 1 Ranger Troupe , and 1 Windrider Troupe for each Spirithost taken.
PostPosted: Tue Apr 06, 2010 11:14 pm
Right.
Only one 'living' formation per Spirit Warriors Warhost.
The "or" in "may not have more individual Eldar Guardian Warhosts,
Warhosts
" is an "or" exclusive, not an "or" inclusive.
PostPosted: Tue Apr 06, 2010 11:51 pm
Warhosts.
Italics added. The 'or' makes it clear that each of these are to be considered seperately. If they were to be considered together, it would be an 'and'.
PostPosted: Wed Apr 07, 2010 12:51 am
Also, the use of the word 'individual' seems to reinforce it.
If it was only to be one 'living formation' per Spirit Host, removal of 'individual' from the list of applicable units, and adding 'in total' to the end would be a better way of writing it instead.
Example
Iyanden suffers with a depleted population which has driven them, in times of need, to raising Spirit Warriors to fight in their stead. As a result, Iyanden Craftworld Eldar Armies may not have more Eldar Guardian Warhosts, Aspect Warrior, Ranger, or Windrider Troupes in total than they have Spirit Warrior Warhosts.
But then,
Iyanden suffers with a depleted population which has driven them, in times of need, to raising Spirit Warriors to fight in their stead. As a result, Iyanden Craftworld Eldar Armies may not have more living formations (Eldar Guardian Warhosts, Aspect Warrior, Ranger, or Windrider Troupes) than they have Spirit Warrior Warhosts.
would maybe be a better way of wording it, if that's it's intent.
Not that I necessarily like the way the rule works. "Hey, guys. We're going to go fight the
Orks. I'll take Harley, Davidson, Honda, Triumph, Yamaha and Suzuki. Sorry Ducati, you can't come. Quota's full. But you 40 Guardians, 30 Aspects, and 40 Scouts can.". Reeks of affirmitive action. :) And how come I can take 8 stands of Rangers, but only if I don't seperate them into two groups?
But anyway, I digress. A lot.
Morgan Vening
PostPosted: Wed Apr 07, 2010 1:32 am
Warhosts.
I was under the impression that you must have equal to or more Spirit Hosts then all and any other "Living" formation in your list.
Example:
1 Guardian Warhost, 1 Aspect, 1 Windrider and 1 Ranger could only be played if you had four or more Spirit Hosts as well.
PostPosted: Wed Apr 07, 2010 1:39 am
Not as far as I'm aware. I've always understood it to be that each 'living' formation gets as many choices as Spirithosts, similar to the Clanrat restriction in the old Skaven Army Book. Perhaps Chroma will appear in a poof of smoke and clarify the situation? I believe he wrote the rule, originally.
PostPosted: Wed Apr 07, 2010 1:58 am
*POOF*
Ah, no, it's meant that for each Spirit Warhost you can have one each of Guardian Warhost, Aspect, Windrider and Ranger Troupe.
If you wanted *two* of any of the limited formations, you'd need two Spirit Warhosts first.
I "inherited" the rule from the previous Champion and think I could use some work; any thoughts on how it could be re-written/re-done?
PostPosted: Wed Apr 07, 2010 2:12 am
Personally, I don't think it needs work.
If it were to be rewritten, I would suggest including Spirit Warrior Troupes in the "dead" category. Then it might be possible to make it a "more dead formations than living ones" style rule. However, at first glance, this change would:
1) Reduce activation count in what is already (in my experiance) a low count army.
2) Possibly (I'd have to make up some lists) make the only viable strategy a Wraithgate based one.
Thoughts?
PostPosted: Wed Apr 07, 2010 2:13 am
*POOF*
*Cough Cough*
*Waves 'Poof of Smoke' away*
Well I guess I misunderstood. Your view seem more playable anyways. I'll have to give it some thought about a better wording or even rule.
PostPosted: Wed Apr 07, 2010 2:20 am
It would also allow armies with NO Wraithguard, only Spirit Warrior Troupes, so perhaps not.
I would say the rule does not need to be changed, though a rewording might help. Not sure how that rewording might go. though.
PostPosted: Wed Apr 07, 2010 2:24 am
What's the feeling about moving Guardians to the Troupe section? Then the rule would be void as you would have to run Spirit Hosts.
Crazy Idea? Maybe....
PostPosted: Wed Apr 07, 2010 2:31 am
Well, the problem is activation count. Guardian Warhosts are needed as cheap activations to get more support formations and boost activation count. Move them to the troupe section, and they will be a part of the problem. If I need to spend 350pt to get any support, it will be hard to get 3 activations per thousand, especially if I take Wave Serpents or Wraithlords, or even Wraithseers to go with.
Last edited by Spectrar Ghost on Wed Apr 07, 2010 3:10 am, edited 2 times in total.
PostPosted: Wed Apr 07, 2010 2:38 am
May be a typo but the Guardian Host is 300 points in the Iyanden List. So I don't think 50 pts is going to make a difference if isn't a typo.
*Rubs Chroma's Lap*
PostPosted: Wed Apr 07, 2010 2:41 am
It's a typo. 150pt just like everyone else.
